Dusty ST
Put another years road tax on it, was going to SORN it  :doh:, so good to go through Summer 2019 :onya:
'02 GSX1400 K2
'08 1050 Sprint ST (RIP :( )
'17 1050 Tiger Sport
Thankfully I dont have a "season" as I ride all year round.
Quote from: Speedy1959 on Monday, 24 September  2018, 06:23 PM
And me but I usually sorn two of them.
MarkN
Fitted the top box and pannier racks today with the fitting kit supplied by Givi. Took a month to arrive but better late...
I should say fitted it with half the kit and half with stuff from my toolbox/garage cupboards as literally half the stuff they supplied was no use - possibly for a different bike :frustrated.
The bolt to replace the footpeg was too short, I had to use a nut and about six washers to stop the left rack side fouling the bodywork :jack: I can only think there was a spacer of some sort missing from the kit. This will have to come off and be re-done another way as it looks shite
On the plus side she's now ready for touring :boogie: (When the Heath Robinson nut and washer scenario has been rectified)
That's odd on the pannier rack, mine have a tube attached to the rack that lines up with the bolt hole in the rack.
MarkN
Quote from: Hooli on Thursday, 27 September  2018, 05:34 AM
I think I must have been sent a Friday afternoon kit as I would be willing to bet I should have had something like that - will just have to see what I can sort, I would imagine I may as well pull faces at my c@?k as get Givi to send me the right bits
If it's any help mine look like this & the tube bit is part of the structure of the pannier racks. It should be an allen bolt but I had to drill it out years ago & buggered the thread so a longer bolt was used instead.
Take tools to check fixings are tight have found mine do loosen sometimes.
MarkN
Quote from: Hooli on Thursday, 27 September  2018, 05:51 AM
Cheers for that Hooli, it's the sort of thing I had in mind, some sort of sleeve over the bolt. Shame it didn't come with the kit :bugga:
The tube is brazed into the structure of the rack, but as you say a shaped bit of tube as a spacer would do the job fine.
DTTW
Drained the oil and installed temperature sensor for my new oil temp/voltage meter. Still struggling where to install the unit but have got some idea already.
Now as the oil is out I have golden opportunity to get rid of those marks on engine side covers. I will keep them probably unpainted. What is the best method to get rid of the old lacquer, machine or manual work?
You can do it yourself with lots of fine grade sandpaper, but easiest is to send to professional polisher, lot less work too & they usually come up very nice indeed.
northern
Quote from: DTTW on Sunday, 30 September  2018, 12:34 AM
I use eccentric grinder. Also scotch brite wheel for small angle grinder. Also dremmel tool with small scotch brite bits. This is as a first step...
And a lot of manually wet sanding... And then polishing with buffing wheel...
But side covers aluminium is not the best to keep it's shine. (For example, audi oem wheels are much better). Last winter, I decide to point it over. White (bad choice). This winter will pain them to repaint them again. This time, for sure, will also cover them with strong clear coat (2K or powder)
