Dibley's New (old) 1400 K3
Started by Dwain Dibley, Wednesday, 08 March 2023, 06:35 AM
Dwain Dibley
Yes, we found it easier when we put the springs back in Hoolie, and came to that very conclusion, as you always do in hindsight.   :rolleyes:
We live and learn.
D.D.
To Infirmity and Beyond.. :-)
The years I spent ramming broomhandles & home made tools down to hold the dampers before I found that out....
I still normally forget as well.
Dwain Dibley
Went out today on the 14, on a round robin to test out the new seals. They got a good test, cos the roads round here are full of pot holes and speed humps.  :computer_type:
Ended up at Son in laws, just to check in and tell him the job was a good un, and the seals were fine. It had rained on the way there, and when I had parked up I noticed an oil rainbow under the bike on the RHS. Oil was weeping from the Oil pressure switch.
So hopefully that will just be a simple tweak or a new seal washer.
D.D.
I suspect you mean the fan switch. RH side, in front of the silver cover low down on the front of the engine & a single wire going backwards along the frame tube off it?
From memory the oil pressure switch is inside that engine cover so can't be seen.
Dwain Dibley
Thanks for the info Hoolie.   :smitten:
As it turns out on closer inspection, the leak was from the timing rotor cover. None of the bolts were very tight, the bottom two were loose, or as near as dammit. I torqued them up to 11 NM as per manual and all good.
D.D.
red = oil leak. Blue = no oil.
Nice easy fix then. There's not even much oil in that cover normally which helps keep any leaks small.
Dwain Dibley
Yeah Mate, If the road had not been wet, I would never have noticed. Until I lost a bolt or two.
D.D.
Didn't your S.I.L do all the spannering on your bike? I'd suggest a sharp rap on the knuckles with a size 22 ring spanner to remind him to check all bolts he's touched...
Dwain Dibley
Neither of us had touched that cover Eric, so cannot blame him, plus he has 5 bikes and is a meticulous mechanic. The only people who could have opened the cover, are the P.O. and the place I bought the bike from.
I have torqued the bolts up to 11 Nm as per the manual and all good.
Went for a blast to test the bike and my new boots today, the bike had no oil leak and the boots were comfy.
D.D.
New Boots.
Awesome, good to read that mate. Comfy boots makes all the difference, glad you've got no oil leaks.
FlyWheel
Dwain Dibley
MOT Day today, can you believe it's been the wettest most miserable day this week....it was sunny yesterday..
What a piss take, the bike is filthy.
She got a shiny new MOT tho, so was way faster on the way back home...  :coffeescreen:
D.D.
Rynglieder
Quote from: Dwain Dibley on Friday, 21 February  2025, 12:02 AMMOT Day today, can you believe it's been the wettest most miserable day this week....it was sunny yesterday..
D.D.
Well the sun is going to shine again tomorrow (Saturday), so I'll be taking my GSX out somewhere - drop me a PM if you fancy a run out.
Pete.
Dwain Dibley
Gave the old girl a wash with the Mucoff sno-foam and pressure washer,in between showers.
This little pressure washer has 3 nozzles, including one for motorcycles and one for pushbikes, with less powerful jets.
I washed her once and dried her 3 times.   :rolleyes:
Did you get out Pete ?
D.D.
Rynglieder
Yes, 130 odd miles up to Cheshire: https://gsx1400owners.org/forum/index.php?topic=375.msg110282;topicseen#new
Back end of next week is looking promising at the moment, so looking forward to setting off again.
