Doess your first gear sound like dry bearings too?
Started by Class—, Sunday, 23 June 2024, 11:13 AM
Class—
Well after resetting it I still have a wierd 2nd gear showing at high rev in 1st and again showing 2nd in netrual. I also found this  https://www.healtech-electronics.com/docs/GPDT-S01_Manual_en.pdf which I believe to be my manual as I have no "L" for learning. It states I need need a new gear position sensor, is that an easy thing to replace?
Thanks
Class--
05 Blue n White GSX1400
Elongated centre stand to accomodate 2003 exhausts
110Kg with kit and planning some suspension upgrades
Class—
Well after using the brilliant search button i found this topic https://gsx1400owners.org/forum/index.php?topic=7094.0
with this post in it
Quote from: Tim1954 on Sunday, 18 September  2022, 10:57 PM@Stevel3
Remove the plastic sprocket cover. Below the clutch slave cylinder you can find the GPS. See service manual page 3-18 topmost figure, the GPS is the white thing, although it probably is not white in your bike but covered with dirty chain grease. Clean it first from outside with WD-40 or similar. Open the two allen bolts and carefully remove the GPS so that you don't lose the little parts, see the figure at the bottom of the same page. Check also that the o-ring is in place around the GPS. Clean the contact surfaces with sandpaper and reinstall the GPS.
So I will try that.
Cheers
Class--
