A bit of fun (courtesy of CoronaVirus Global)
Started by gsxbarmy, Saturday, 21 March 2020, 09:17 PM
So just for a bit of fun - assuming that others worldwide are on shut down and self-isolating - what are your answers to the following questions (funny or serious, I don't mind as this is supposed to be for fun). All questions relate to the GSX1400.
1. Which is the best oil to use and how often should I change it?
2. What is the best oil filter I can use?
3. I need a new air filter - which is the best one I can buy?
4. What oil should I use in my forks. How often should I change this?
5. What tyres are the very best for my bike?
6. My bike won't start. Why?
7. What are the best disks to use?
8. What are the best brake pads to use?
9. How often should I change the brake fluid. What fluid should I use?
10. My rear suspension is leaking. Can it be fixed? Do I need new rear suspension? Which should I buy?
11. I know the GSX1400 is a naked bike but what fairing or screen can I fit?
12. I want to change the twin exhaust on my bike - which is the best after market twin exhaust to purchase?
And the tie breaker. Place these GSX1400's in the correct order, fastest first, slowest last:
A. Blue and White
B. Red and Black
C. Black
D. Blue
E. Primer (sorry Silver)
Enjoy! Let the fun begin  :whistling:
Quote from: gsxbarmy on Saturday, 21 March  2020, 09:17 PM
Any good quality 10w/40 semi synthetic oil (i use Halfords) changed every 4000miles
Any I use a Suzuki or champion filter changed every 4000miles (they are less than £4)
K&n as they can be cleaned in the standard bikes pod filters on the tuned bike
The correct for my hagon springs (can't be bothered to go look in the garage for spec)
I use Pirelli angle gt2's on all the bikes
No have ever not started yet (the red and black did have a moment last month so I replaced the 15 year old battery)
We have either original standard discs or ebc
Ebc HH front Ebc rear.
Halfords dot 4 change every 4-5 years
All shock still ok
Its worth following the fix before replacing.
I have had hagon on the back and were great the tuned bike has wp shocks
The 2 standard bikes have give A720 screens the tuned will have a gpz style Twin headlight set up
Fit an akroprovic and yoshi cams
A. Blue and White fastest 136 bhp
B. Red and Black standard
C. Black emma's  (as fast as standard if I ride it)
D. Blue standard and looks nice
Should be slightly quicker than standard as has less paint on it .
Okay I'll play.
A.  Smith & Allan fully synthetic, change it at 4000 miles.
A.  HiFlo HF138
A.  Standard Suzuki.
A.  Smith & Allan 10w fork oil.  Change every 5 years or so.
A.  Continental Conti-motion.
A.  No petrol.
A.  Standard Suzuki or EBC.
A.  EBC Organic.
A.  Every two years with a good Dot 4.
A.  Yes it can so no you don't.  If you must buy Hagon if cash is in short supply and Ohlins/Maxton.
A.  Not applicable, its a naked bike.
A.  Probable Akrapovik.
A. Blue and White
B. Red and Black
C. Black
D. Blue
A to E in that order from fastest to slowest.
Cold pressed raps oil. Change at recommended 6k km intervals. Used oil is really tasty in the kitchen and supplies essential trace metals.
DIY from coffee filters.
DIY from toilet paper.
Burt's Bees Baby oil - all natural ingedients. Never need to change oil again. Fork seals will outlast the 14 engine.
The tyres off T24's tractor.
Forgot to turn the ignition key.
Fast and Furious DVDs.
Always - the one with the wings.
Mice milk! Replace as often as you are able to collect enough milk. How to do this effectively see: https://www.ncbi.nlm.nih.gov/pmc/articles/PMC2789213/
Can't be fixed. Replace with pogo sticks.
This should do fine:
No need for after market, plenty of bazookas available:
No need to put this in order as the warp speed capable Galaxy Silver outperforms them all  :grin:
Big Geordi
1,Motul Fully Synth
2,Hi Flo
3,I don't have an Airbox
4,Return to Maxton
5,Michelin Pilot Powers
6,cause your stupid!!  ;)
7,Galfer
8,EBC Sintered
9,Yearly at least every 2
10,yes,just buy Nitron Race Spec
11,Wes Cooley
12,Dont know Akra Rules!!
Blue and White rest are not relevant!! :stir:
A. Blue and White
B. Red and Black
C. Black
D. Blue
1. Olive oil
2. 120 denier tights
3. 80 denier tights
4. Sunflower oil, changed every 10mins
5. Whitewalls
6. The warp coil has discharged due to excessive kryptonite in the tardis
7. Compact discs
8. The ones you've already got fitted
9. Weekly & use superglue for extra stopping power
10. A welder & hardtail it with plywood struts
11. Sellotape your old conservatory on the front, it'll look better than any aftermarket screen
12. 1/2" copper pipe for the two smoke look
I don't get the tie breaker, it's already in the correct order. Is it a trick question?
A.  Baby. When she stops being slippery.
A. A normal kitchen sieve ought to be fine.
A. One of those surgical facemasks, but hard to get at the moment.
A. yeah yeah April 1st I get it. Just like spoons, forks don't need oil.
A. The round ones.
A. Kill switch
A.  Compact.
A. You shouldn't use break pads, get ones that won't break.
A. I always do mine at the same interval as the blinker fluid.
A.  Of course. For a while. No. The best one to show off.
A.  You can buy a large givi touring screen from me.
A.  Twins are for bedtime. Get a 4-1
A. Black / Red & Black
B. Daylight
C. The other ones, nobody cares.
