Broken gauge housing
Started by ringfeder3, Thursday, 05 March 2020, 03:28 PM
ringfeder3
A mishap has resulted in me needing to replace the complete speedo/ tacho gauge housing assembly on my K7 pride and joy.
The replacement part will be a eBay non-genuine one but I am a bit hesitant about the changeover process.
Can anyone provide a simple step-by-step guide to swapping it all over?
Thanks
ringfeder3
I should clarify that only the housing is damaged. I need help to:
1/ install old gauges into new housing.
2/ remove and refit gauge housing assembly to bike.
Thanks again
I haven't time to check at the moment - should be in the workshop manual?
That's available via the DOWNLOADS tab in the top menu here on the forum.  :onya:
Quote from: ringfeder3 on Thursday, 05 March  2020, 03:28 PM
Thanks
Really quite straightforward to do - all you need to know is here
https://gsx1400owners.org/forum/index.php?topic=2033.0
If it's only the outer case you're replacing then I'm sure there's only two screws to undo and I think the after market one is a straight swap.
This is the one I bought. https://www.ebay.com.au/itm/Gauges-Case-Speedometer-Tachometer-Shell-Cover-for-Suzuki-GSX-1400-2004-2008-05/263770864267
