Workshop non negotiables
Started by Horse, Sunday, 27 April 2025, 04:20 PM
Horse
In the interests of finding products that make life easy thought I would ask what consumables people swear by , I will start with these 4 that reliably perform above and beyond and in my opinion are far superior to similar products.
INOX lubricant/penetrant that doesn't dry out and harmless to nearly everything
CARBON CONDUCTIVE GREASE great for electrical contacts protects from corrosion and lowers resistance
3452 SYNTHETIC GREASE High/low temp grease that is chemically resistant to lots of substances
LOCTITE 567 hydraulic sealant good for all hydrocarbon sealing duties as well as other liquids I use it on sump plug washers instead of replacing them it then also serves as a slight resistance to the plug backing out
 Chime in if you have products others might not know about , i realise some of these might not be available internationally
Regards,
Horse,
Change is easy improvement somewhat more difficult :Dr Porsche
Agree loctite &inox. Lanox also. NeverSeize, VMX gear oil-for my chain. Micro fibre cloths, SolvolAutosol, brake&carby cleaner. Synnex3000 oil,use in cars, bike, mower& whipper snipper.Im sure i have other must haves but thats a start.
Nickelslip anti seize grease. Messy, but stops bolts seizing up, especially header bolts as it's more heat resistant than Coppaslip.
