Gear Pedal Bush
Started by froudy, Friday, 12 October 2018, 05:40 PM
I'm sure this has been covered, but has anyone re bushed the gear change pedal?
Mine has a fair bit of play in it now and I'm sure it's causing my sometimes rough gear changes.
New gear shift lever is £54.77 and the shaft is £12.40..There must be a cheaper way of sorting it.
I had one on another bike done years ago.
A 6 pack of his favourite beers and the guy re-did it like new on his lunch break.
Any small engineering places near you? Cash job?
Thanks Andre and Tony :onya:
I can remember your write up now Andre..I knew I'd seen it on here some time in the past...Very helpful :onya:
Froudy, if you cant find, ill post you one.
Quote from: grog on Friday, 12 October  2018, 07:25 PM
Thanks @grog That's very good of you. I assume I need two of them?
I've found them and have a friend in Germany, so I'll ask him if he can get them and send them over for me.
Any problems and I'll give you a shout..Thanks :onya:
just need one, some washers either side. need to ream out gear lever a bit to get bush in, all very easy.
Just a quick update on this thread.
I actually purchased a new gear lever at the silly price of £55 as the bushes were really badly worn and causing bad gear changes. I'm going to re-bush the worn one and keep it as a spare.
The bushes ARE available in the UK :onya:
I ordered 2 of them and now awaiting arrival.
https://www.ebay.co.uk/itm/Glacier-Split-Bearing-Bush-12mm-x-14mm-20mm-x-9mm-Flange/123113213850?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
froudy, a great find, everyone should have as spares. are they metal or plastic?doesnt really matter.
Quote from: grog on Saturday, 11 May  2019, 06:02 PM
The one's I took out are hard plastic..I think the new ones are metal..
I'll update when they arrive :onya:
Arrived but not fitted yet...
Froudy, if they fit easily, should be a best seller. Ive done mine with others but would choose them as no separate washers.  :cheers:
They look a bit different to the sales pic. That looks like stainless & these look like ali.
@KiwiCol
They are a hard metal and not aluminium :onya:
