Odometer acting strange.
Started by DanGSX, Monday, 15 April 2019, 06:38 PM
Quote from: DanGSX on Wednesday, 17 April  2019, 06:34 PM
@Hooli Am I correct in believing that the mileage will be stored in the ECU? So essentially it will still be counting correctly, but I'll never get to see the correct result on-screen.
Aye I believe it's stored in the clock's ECU, as the mileage follows the clocks if you swap them between bikes.
Mileage is def stored in the clocks  :onya:
Monarchjock
I could come over and have a look if you like Dan. I have replaced the leds in the display with blue ones so have the necessay skills if a repair is required? Sounds like there could be some internal damage from the description of your other symptoms.
@Notty
He has a k2 but the parts he should need are the same if they transfer the LCD screen between units .
:onya:
Del
Quote from: seth on Thursday, 25 April  2019, 09:37 PM
@Notty
:onya:
They are as the clocks I swapped over had the later clock covers (with immobilizer)  which I needed to swap to fit to mine but everything works on my K2
All Lives Matter
