A rust issue
Started by Johno, Tuesday, 08 January 2019, 03:07 PM
Johno
A spot of maintenance during the hot weather here.
Cleaned the Air filter and put in a new set of spark plugs.
.....and found this under the tank!
A mate has some rust inhibiting/converting paint. Appears to be only just under the painted surface and only around the frame lugs/brackets.
Has anyone had similar issues?
I did a forum search and found more severe rust issues in tanks.
Any thoughts/recommendations regarding treatment.
Johno
GSX1400 K5 now sold
1981 GS1000G
shanered6
Its a very common problem on 14's and if you look through the forum you will find plenty on it .
Mister Fishfinger
Mine is exactly like that. Same colour too!
And my B/W the same  - now painted with BLACK Hammerite  :)
Yeah Mate, lots of ways to fix it. Not a serious problem. My fix was easy, rust converter, apply and let it work. Can paint or apply protector. I just used Tectyl, spray on all unseen places. If worried about inside, get pump out, have a look with torch. My way is a tank of 2 stroke mix once a year, just use it up in one ride, doesnt hurt bike at all. A few litres of e10 also, sucks all moisture thru, again use in one ride, dont let it sit. Rest of time, Wynns make a brilliant fuel cleaner, our stock use at work on every car service. It cleans but also takes out all moisture. https://www.wynns.eu/product/dry-fuel_consumer/
Same problem in my B/W. I have used spray oils outside the tank and a drop of 2-stroke oil among fuel during winter time.
