C42 code help
Started by SBeachill, Sunday, 23 May 2021, 05:52 AM
SBeachill
Got a C42 code up on my project bike,  K5 model,  have cleaned all connections,  checked electrical plugs and relay etc,  pump only primes for a second,  can get it to prime by messing switching the kill switch on and off,  have read this could be ab antenna problem is there anyway of eliminating this before purchasing a new or replacement one?
Cheers Steve
If it is an antenna problem Steve, that was the subject of a recall by Suzuki for the K5's, so you can check with Suzuki GB if it has been done or not. If not, then they should replace for free
Steve...
Due to what you have said ref the kill switch, I would clean the contacts and try again :onya:
SBeachill
Quote from: gsxbarmy on Sunday, 23 May  2021, 08:06 AM
Ne a bit difficult getting them to replace it on this lol
SBeachill
Quote from: froudy on Sunday, 23 May  2021, 05:30 PM
Steve...
Did a full check on kill switch continuity etc and all good 😊👍 so can only assume antenna or something else within the C42 circuit?
Pitkatukka
How did this story end?
Did you find the problem?
Pitkatukka
Hi
The story ended with that Suzuki had that recall campaing about antiteft collar, i towed my bike in our local Suzuki dealer and they replaced the collar and now it works like a charm!
hard road
Quote from: Pitkatukka on Sunday, 11 June  2023, 05:10 AMHi
liking the ET project, any more pic's ?
