Swing arm, repaint or strip and polish?
Started by SteveJ8672, Wednesday, 29 April 2026, 05:51 AM
SteveJ8672
So the swing arm has cleaned up reasonably well, but there are a few larger areas where the lacquer has worn away and corrosion has set in, is there a reasonable match for the silver in rattle cans so I can patch, or is it easier just to strip and polish the whole lot out?.
Used to be known as Nomad of the SOC many years ago, I'm just old. 2003 B&W being lovingly & painfully restored in the mancave. @VBG-thementalhealthrider
lurch
They're clear anodised from factory. Mine had some cloudy areas. I had it wet blasted and coated with Cerakote MC-5100. It mostly lost the "brushed alloy" look in the process but I actually prefer it this way since there's no other similar finish anywhere on the bike to be honest,
I also took the opportunity to weld on some paddock stand bobbin mounts.
SteveJ8672
Quote from: lurch on Wednesday, 29 April  2026, 06:17 AMThey're clear anodised from factory. Mine had some cloudy areas. I had it wet blasted and coated with Cerakote MC-5100. It mostly lost the "brushed alloy" look in the process but I actually prefer it this way since there's no other similar finish anywhere on the bike to be honest,
Thanks mate, that looks spot on. :onya:
Podpeeze
Had mine polished but it was a long long time ago!
@Podpeeze do you have a current pic to compare ?
How are the Conti's ?
Podpeeze
Quote from: GSXKING on Sunday, 28 June  2026, 08:33 AM@Podpeeze do you have a current pic to compare ?
Ah that was a previous 1400 mate.. had it professionally polished so hopefully it lasted well but I sold the bike soon after. Ironically I have contis on my current 14. Just the job for what i need but to be honest I'd be unlikely to put any brand of tyre under enough pressure to test them properly  :happy1:
