Hello
Started by Yami, Sunday, 16 May 2021, 09:44 PM
Yami
Hello forum members.
Joined here over a year ago and has been lurkin around.
Thought I had done a presentation earlier, but not. So here it is.
I live in the south of sweden and like bikes. Discovered for a couple of
years ago what a great bike the GSX1400 is. I have had my 14 since then
and it´s a 2003 model with 13000 km on the clock. See yah.
Gidday Yami & a belated welcome to the forum.    :onya:
With a handle like that, do you have an XJR as well?   :confused1:  :whistling:
Good to see you in the bar .
Hopefully you get to the bottom of your issues.
I would use the pressure regulator that matches the the year of your bike.
So if earlier model the k3 if later k5 one .
Also search the fuel regulator wire mod as the plastic clip can break allowing it no not maintain pressure properly .
How many miles has your bike done ?
G'day Yami, welcome aboard   :cheers:
 Välkommen Yami  :hat:
Welcome to the forum Yami.  :onya:
BbigMmac
Yami
Quote from: KiwiCol on Monday, 17 May  2021, 03:40 AM
I have had one about 10 years ago. :)
If I don´t find out the issue with the 14 soon, I will get one XJR again because
I need to ride a bike this summer.
Quote from: seth on Monday, 17 May  2021, 05:46 AM
So if earlier model the k3 if later k5 one.
My Haynes doesn´t mention any difference between the pressure regulators, it´s 02-08 yearmodels in it.
It only says 48 psi (3,0 bar). I have borrowed a 2005 fuelpump/regulator to my 2003 which I have the issue on.
Yes, I have seen the wire mod but when I dissasembled the fuelpump plastic looked fine and the regulator
is tough to get out. But I will do the mod later on.
I have 2 GSX1400 but non of them is a runner for the moment for very obvious reasons. I have had a K5 yearmodel for some years
and that one has soon 110000 km on the clock but was working fine. The K3 which has the issue has only
I will update my issue thread with this info as well as the K5 is very much involved in solving the problem.
@Yami
You do know you can download a full Suzuki workshop manual here for free .
Your bike has a problem and you need to go through it in a systematic way and you'll get it sorted .
Plenty of help here you just need to call down and take your time.
It's frustrating I know but just keep cool and go at it bit by bit rather than at everything at once and you'll get it sorted out .
