Next Oil Change
Started by Andre, Saturday, 20 May 2017, 03:22 AM
Veemanzero
Motorcycle oil, if its not a supersport spinning at up to 13000 revs and manufacture says semi. Use 10-40 car oil. Same shit different label. Never had a problem. Frequent changes are Important to avoid the shearing effect.
northern
Quote from: Jeykey on Wednesday, 14 June  2017, 02:51 AM
110ºC or 120ºC ? I´ve read, don´t know where, it starts to run at 120ºC. Don´t know when it shuts down. Anybody knows ?
According to GSX1400 service manual:
Cooling fan thermo-switch operating temperature
Standard:
(OFF→ON): Approx. 120°C (248°F)
(ON→OFF): Approx. 108°C (226°F)
Jeykey
Veemanzero
I think your wasting your time, you won't get a litre out of the cooler. I had to disconnect mine to replace the o rings. And not much came out. Besides theres a litre sat in the head that you will never get out. I think your better off changing the oil more frequently or if money is not a issue and you want to be super sure flush it with some cheap 10/40.
Just saying
