I can't see an issue with just replacing them with bolt on ones. Just tidy up the old welds so if you're worried about it.
I didn't think I'd been using my 14 enough so I went to Reeth, North Yorks for sunday lunch & came home the long way via Tan Hill. It must be summer as I took my jacket off to sit by the fire in the Tan Hill Inn.
Oh & the last pic happening means three things -
1) I've done 4,032miles since 30th April
b) I've done 14,032miles since this day last year
iii) It needs a service, again
Quote from: mjgt on Saturday, 22 June  2019, 06:14 PM
Quote from: froudy on Friday, 21 June  2019, 09:39 PM
Fitted my newly recovered seat.
I had it done by Grizzley Adams. He did the work and returned it to me for the grand total of £65..Bargain!
I've fitted two covers myself in the past, but they kept splitting where the seat met the tank at the front. He's repaired the damaged foam, so it shouldn't happen again.
Do you have his address froudy?
Contact him via Facebook messenger and he'll sort you out👍
I'm away in Cornwall for the week with no laptop and limited net access so difficult to sort details..sorry.
Quote from: froudy on Monday, 24 June  2019, 08:09 AM
Thanks mate but I don't do facefuck.
Quote from: Speedy1959 on Monday, 24 June  2019, 12:49 AM
Bob pointed out to me that the centre exhaust clamp bolts that hold the headers to the collector box have corroded and snapped..
The actual collector box seems solid enough..
I gather the clamps are welded on, so that means i cant just replace with some decent stainless clamp bolts..
Oh and is likely to cause an MOT FAIL ?
As long as the pipe is not leaking you should be okay for the mot.
Del
#2645
Quote from: mjgt on Monday, 24 June  2019, 07:13 PM
Agreed
All Lives Matter
132k service done tonight. I took the cam cover off to sort a slight oil weep & checked the clearances while I was in there, still identical to when I first looked at 15k. I balanced the throttles too, so she's nice n smooth again.
Donatello
I installed my 2nd hand akra system but I'm not to pleased by the spring location of the inner two tubes. Maybe you guys could shed some light on how the orientation has to be on the inner tubes, I can't find an install manual online sadly.
northern
@Donatello
Mate, seem's you assembly it little bit wrong way - the thick alu plate, what press header to engine have to be rotated:
  • outer - spring hole up
  • inner - spring hole down
From the picture, it looks you put them opposite way.
there are pictures I made previously, but you should see, what I meant.
getting frustrated trying to remove the goddam regulator/rectifier it's in a shitty spot.  :furious: :furious: :furious:
@GSXKING  I was fretting to do the rectifier job but then surprised of the relative ease.
I put the bike on its sidestand and looked through the side frame triangle to place the tools (good lighting helps). Maybe I have the advantage of long arms :whatever:
Donatello
Quote from: northern on Monday, 01 July  2019, 05:50 PM
@Donatello
I tried it that way also but even then it's hitting the frame. I managed to swap out the inner two tubes so the springs are on the other side now.
Quote from: GSXKING on Monday, 01 July  2019, 09:08 PM
The offical way is to remove all the rear bodywork off the bike to get to it.
I found that grabbing it & giving a good twist broke the original rivets so it fell out, it must have been near falling off tbh. I think just managed to get a couple of small nuts n bolts in to refit it.
The rivets on mine are slightly loose. So something on the to do list.
