Paulr5604’s bike
Started by paulr5604, Monday, 29 April 2019, 01:57 AM
Good to hear it's running again. As you & Barmy said, it might improve with use as the old fuel gets washed through and stuff like gummy injectors get washed clean.
My 14 hates cheap unleaded so I always run it on E5. Otherwise it's rough, slow & thirsty. No idea what you've put in it but Barmy's idea of using posh fuel is worth a try as well.
paulr5604
Thanks guys I just filled it with normal unleaded will put premium in next time along with some injector treatment I think it will be fine to be honest just need a few long runs to get it nice and warm etc
I think one of the best things about this ORG is the fact you can go "off topic" quite easily and not many make a fuss. I applaud you all. It's a great environment and should be celebrated  :clapping: :clapping: :clapping:
Good on you Paul.  :hat:
paulr5604
Quote from: GSXKING on Sunday, 13 March  2022, 11:21 AM
It is just like when you a talking with people in person how often do you stick to one topic.
paulr5604
Just took the instrument cluster apart to try and find out why the select button doesn't work and I think it is obvious why it doesn't work. There is no select button the reset button and wiring is there but nothing in the position where the select button should be.
Does anyone know where I can get hold of a replacement
Quote from: paulr5604 on Sunday, 20 March  2022, 02:58 AM
You could try pm'ing Thommohawk, he may have one from where he mods the clocks etc
paulr5604
Quote from: gsxbarmy on Sunday, 20 March  2022, 04:50 AM
Thank you I will try sending him a pm
