crank case breather
Started by spizzoil, Sunday, 23 April 2017, 02:06 AM
spizzoil
fitted this today was only £50 with p+p and is the dogs bollocks .have to say once fitted and striking the bike up the revs were different normally the bike takes a while to settle to the 1100 rpm but this time it took about 15 secs .and just purring at 1100 rpm so don't really know what the difference this has done on the tech side of things but I like .hope to take for a blast and see if it makes the ride better. tomorrow .have read that this can be done with revs with the tps but this seems to have smoothed the revs and the cold start out never did I have the rpm settle that quick before .
kja
Not seen one like that before Spizz, looks a tidy job though, well fitted.
spizzoil
hi m8 seen a few but like you said not like this and the cylinder unscrews half way down so you can empty the crap out ebay again .
coldhands
Remember every car driver wants to knock you off !!!!
Looks good Spiz - I have been watching this one on Fleabay thought it looked good but wasn't sure wether it was of any actual use except bling ! :smile2:
http://www.ebay.co.uk/itm/282440505191?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
spizzoil
hi m8 it is bling and very good bling .this has sorted a problem I have had and seems a few others have had so far and thought I would be going down the tps route but I think after todays start up test I think I'm ok.never have had the revs from cold start smooth out so quick .
looks good. not sure how it could change the way motor runs but if it does, it does. i wont fit as id have to remove my little temp gauge, been there so long it belongs.
