Fuel hose routing - cannot fit LH side panel
Started by gld1400, Monday, 11 August 2025, 04:12 AM
Take the rail off and get fitting refitted correct position.Id be brazing it but whatever works.
Quote from: grog on Wednesday, 13 August  2025, 04:22 PMTake the rail off and get fitting refitted correct position.Id be brazing it but whatever works.
From memory it's two screws to remove the rail so it's not a TB out job, makes it much easier.
Yup, as per Hooli's advice, two bolts or screws. You can see the lh one in my photo, just under the hose connector. The outer one holds that bit of plastic on thet hides injector#1. You will need to disconnect the injector connectors and cut the little zip ties but once unbolted, just wiggle it out sideways to the left.
