Clocks buttons not working
Started by sam61, Monday, 03 April 2023, 06:21 PM
sam61
To add to my misery on this bike I put a oximiser lead on and tried to set time but neither select or reset buttons are working. Can see mileage and time on display but that's it.
Any ideas w he at this is?
Thats why i always ride alone
Dwain Dibley
You have to press both at the same time to enter settings, unless you have already done this.
D.D.
To Infirmity and Beyond.. :-)
What can happen is the pin behind the buttons can get dislodged. If you take the covers off the clocks you'll see what I mean when you take the front off.
It's nothing difficult, just don't overtighten the screws as they are into plastic.
Oh & do it somewhere warm & dry, that way you trap dry air inside the clocks when you seal them back up & won't suffer the clocks misting up.
sam61
Quote from: Hooli on Monday, 03 April  2023, 10:14 PMWhat can happen is the pin behind the buttons can get dislodged. If you take the covers off the clocks you'll see what I mean when you take the front off.
Thank you will try that
