Replacement fuel lines
Started by Noddy, Tuesday, 06 June 2017, 04:22 AM
Noddy
I need to replace the ageing fuel lines on my bike but don't see why I should use OEM lines (except the bends are in the right places) but I can cope with shallower bends. So where is the best product supplier for 6mm ID flexible lines?
Thanks
Remember puddles are always flat on the top!
I just go to my local Suzuki store and buy a length.
That just cut it off a roll, I'm pretty sure it's not a OEM / genuine anything !
any efi hose will work. get efi clamps and cut fittings out of original.
I have used for years  Gates 3225  fuel hose with no problems. And fuel pressure in my turbo 14 can be 6 bar on maximum boost.
You have constant 3 bar if you have original fuel pump and regulator.
