GSX 1400 Ignition
Started by Buck, Monday, 24 October 2022, 02:36 AM
Buck
Hi guys I recently bought 2008 FE just the frame engine & loom & ecu for a chop but I didn't get the ignition or key with it is there a way I can bypass the ignition switch as I have just found out there is an immobilizer & resistor  built into ignition that send power to the EFI system
Any help will be much appreciated thanks 🤘
Quote from: Buck on Monday, 24 October  2022, 02:36 AM
On other Suzuki's it's possible to deactivate it in the ECU, the 14's ECU / Flash is a bit basic in its options though so I'm not sure if this is possible ?
