Want to buy a cartridge tool for K6
Started by Tim1954, Tuesday, 07 December 2021, 04:32 PM
Tim1954
I installed one cartridge and the tool worked well. The bottom bolt could be tightened to 40 Nm. However, before installing the other cartridge I will still improve my tool by tightening the tolerance closer to 32 mm and replacing the wire with sheet metal band to make it stronger.
Tim1954
I have now improved my tool. It fits the cartridge head perfectly and easily withstands tightening to 40 Nm.
The reason why I could not test the tool before was that I had to wait for a replacement bolt for the one I spoiled when trying to open it with an impact driver.
Awesome looking bit of kit you've made there!   Well done, I'm sure you could sell those if you made more . . .
SpongeBob
Quote from: KiwiCol on Tuesday, 18 January  2022, 01:51 AM
Agreed! ;-)
A new & improved tool will never go astray   :facepalm:
