Clutch n Brake Levers
Started by grog, Thursday, 21 November 2019, 07:39 PM
Quote from: grog on Sunday, 24 November  2019, 08:32 PM
Froudy, think you have bar ends turned in. Did they hit mirror heads or bracket they mount on? If they hit brackets i will need shorties. Longs are 170mm, never measured originals. Thanks Mate.
They caught the bar end on the clutch side. Probably by moving the clutch inboard a little it would solve the problem though :onya:
Re boobies see attached. :grin:
Re levers ive had pazzos on my 675, best ever  loved em.  Great quality and loved the adjustability.
I would get them again. You get what you pay for - think about what these levers are doing, id hate for a 50 buck cheapy to fail at the critical moment, then be wishing youd spent a bit more...
I decided to bump this thread because it's relevant to my question.
I bought a set of chinesium levers for my bike some time back - of the extendable type - assuming that I could have them short for easy 2 finger braking, or longer to 'stock' length.
Weirdly though, the short length is teh ame as stocl lever and the extended length is well past the end of the bars ! Very odd indeed.
Anyway I am hoping someone can point me to adjustable length levers of the former variety.  (short.normal) rather than (normal/long) ?
Have a Google for Pazzo levers, had them on my Daytona 675, nice bit of kit.
Pazzo only has short OR standard.
I was looking for a cheap set that I could use both and see which I prefer before shelling out big $ for pazzos.
After recent posts about spare levers, wouldnt mind a set. Just for under seat in case. Some are stupid prices, some are chinese that promise the world. What do i buy?Just a spare set i mean. Do other Suzuki levers fit?
I'm pretty sure the clutch lever I had to buy in Wales once was off a big Bandit they had in the showroom.
The cheap Chinesium levers are fine. Just be aware that with the clutch lever on span setting 1 it might not actuate the clutch switch. It caught me out big time after doing a 12 hour night shift!
It's easily remedied by sticking a small piece of packing in the lever. You could also leave it as it's a simple anti theft "device" :onya:
I had to do similar to cheap levers as on max span they were too close, so I stuck a tiny metal off cut on to adjust it. Oddly the other one of the pair needed a bit filing off as on min span it was too far out...
Can't beat quality control.
