Main earthing bar - is there any?
Started by DTTW, Friday, 11 June 2021, 04:34 PM
DTTW
Hi,
Is there a main earthing bar in these things?  :confused1:
Cruising with my R/B K5 since 2012
a.k.a Thunder Pants
Mate, not totally sure what you mean. Negative lead just bolts to motor. I fitted a parallel extra wire.
Quote from: DTTW on Friday, 11 June  2021, 04:34 PM
Hi,
No @DTTW there isn't. The main straps are battery negative to the frame, and then there is another earth strap between the frame and the engine.
If you are looking for better earthing, this may help? https://gsx1400owners.org/forum/index.php?topic=4828.0
Under the seat beside the ecu area there is a connector that has maybe 6-7 smaller earth wires joining before it the then joins the big back of the motor to battery earth .
Good luck
DTTW
Thanks for the replies. I'll try to figure it out. Yeah, some extra earthing is on my to do list.
a.k.a Thunder Pants
@DTTW
S9me folks add an extra earth from the back of the motor to the frame and then another from the frame to the battery .
I've added the first one after my main earth wire failed .
DTTW
Thanks @seth, good info mate. Certainly don't want the main earth wire to fail on me.
a.k.a Thunder Pants
