Injectors
Started by Marky5432, Sunday, 14 June 2020, 06:54 AM
Marky5432
Mark bates
Welcome :hat:
Quite the unusual intro. :shocked:
A little more info would be helpful. I assume that you got an FI error, activated the dealer (diagnostic) mode which then showed a C33 code indicating that #2 injector doesn't get power.
#2 injector is the one for cylinder number 2. That is the 2nd from the left as you sit on the bike.
Section 4-46 in the manual (to be had in the download section) tells you what to test for.
 :doh: :facepalm:
All the injectors are the same so you could try swaping injector 1 & 2 to see if the fault us the injector or a wiring/control problem as if the injector the is faulty the problem changes cylinder.
If it is the injector
A company called
injector clean listed in recommended suppliers section will clean and service with a report for around £60 for 4 injectors.
Now get to the bar and say hello to everyone as this isn't Facebook.
Good luck .
P.s. depending where you are others here might be able to help you .
Quote from: seth on Sunday, 14 June  2020, 07:33 AM
@seth  He is at the bar :whistling: Not everyone is a social animal or knows how to use various platforms on the net. I haven't seen anyone introducing himself and asking his question at the same time in a poll though. :cheers:
Gidday Marky, welcome to the club.  As Andre said, an unusual intro  :onya:  not a bad thing, just different,  hmmmm, you'll probably get on quite well with Notty!   :rofl2: :happy1:
Welcome Marky!
Some Mitsubishi cars and Yamaha outboard motors are using the same injectors, and new injectors
can be cheaper than cleaning on Ebay.
You can find the code from your injector, I dont remember it anymore,
but I have used several years those "China injectors"
