HSS Wurth Grease
Started by grog, Sunday, 16 February 2020, 07:21 PM
Just a heads up if you want the best spray grease ive ever used. Brilliant for 14, levers, side stand ,clutch switch, whatever moves and open to the elements. Great for car, locks, hinges etc, around the house, gate hinges etc.Not cheap but will last a long time. It sure does a good job.https://www.ebay.ca/itm/WURTH-HHS-LUBE-SPRAY-Grease-Lubricant-Dirt-Repellent-Long-Life-High-pressure-/254036528155
Great stuff. I have used it for years. Good also for battery poles.
Good heads up Grog.  :onya:
Been using it in my trade for years.
My issue with greasing locks and hinges and so on is that grease/oil tends to be a dirt magnet.
Well then Vlad, its exactly what you need.
