Ah bugger
Started by VladTepes, Wednesday, 12 June 2019, 09:44 AM
Did you put the spacers in the right way around Vlad ? :whatever: :whatever:
When I remove and refit the rear wheel is use two very big wooden wedges to make it an easy one man job. One at the front of the wheel and one behind. It enables you to hold the wheel in exactly the right place to refit the spindle.
I used to use the shovel method but it can be fiddly on your own.
Quote from: GSXKING on Thursday, 13 June  2019, 08:22 PM
I think so.
I lived through the ride so I guess it must be fine :)
