Gen TWO Busa wheels
Started by Shifty, Thursday, 30 May 2019, 02:34 PM
Shifty
Hi guys. I'm wanting to fit a set of wheels with speed/abs sensors on them, for a wheelie control system.
I know (?) first gen hayabusa go straight on(?) but apparently not gen 2. Is there a solution here?
Or does anyone know of another and equipped bike I could fit the wheels from?
I think you'll find that whilst there may be options on the front wheel, the rear wheel is unique to the 14 and that no other rear wheel will fit.
Masterbates
What is the speed sensor/pick up system based on? Is it something that can be retrofitted to the GSX ?
Shifty
I was planning to use hayabusa wheels with abs chopper discs and sensors to generate wheel speed data for traction and wheelie control functions.
Front wheel, lots of options such as...?
What's so different about the rear wheel?
It's not been tried but maybe a 1250 bandit abs front wheel might also work but I think that you might turn out to be the pioneer on this stuff .
Will follow with interest .
:onya:
Quote from: Shifty on Thursday, 30 May  2019, 10:48 PM
No idea, but many have tried before, none seem to have succeeded, at least not with the standard swing arm. Those that have succeeded have modified the frame and rear end for a monoshock with associated swing arm etc off other bikes - which may be your only option.
