Hope to be new Owner of a GSX1400 this weekend
Started by BlueDragon, Tuesday, 02 April 2019, 08:04 PM
Luckily you had plenty of fuses on board and finally made it home!
I don't have any suggestions on bar as I changed the lower, wider bar (LSL 01) it came with to the original. Like the more upright position (190 cm tall). No suggestion as to fairing either as I prefer naked and took the fairing off right away.
There are several different options for the smaller fairings.
If your a fan of the Wes Cooley / GS1000S style there's a slightly smaller one that a few members have used.
Web Bike.    AR Breaker.
https://japan.webike.net/products/9373771.html
Put a pic (or 2) up of your bike.  I know you want to mod it, but before & after pic's are good too.
BlueDragon
BbigMmac
Congradulations with your 1400, hope you enjoy it as much as the rest here does.
Mrg
 :cruisin:   :cruisin: your one of us now congratulations    :onya:   :clapping:
Yes congratulations.  :onya:
As has been mentioned....
:useless:
BlueDragon
Will load some pics on the weekend.  The bike is in pieces right now..  yep, already.
I found that when I got home, put the bike in the garage and the next morning there were 2 pools of oil under the rear of the bike..  leaking rear shocks.
So I read through this forum and followed the instructions on how to fix this.  Took me 3.5 hours on each shock.  For some reason, I could only get about 6 drops of oil in each time and that was with a syringe and a needle on the end - trying to get out any air bubbles.
Anyway, I finally got there and will put the shocks back in over the weekend along with some other bits and pieces.  I'll load up some pics once I'm done.
BlueDragon
