Clock Cases
Started by Simonic, Sunday, 28 October 2018, 08:44 PM
Simonic
I need a new set of clock cases. The upper and lower are both damaged.
has anybody used on of these please ?
https://www.ebay.co.uk/sch/i.html?_odkw=gsx1400+instrument&_osacat=0&_from=R40&_trksid=m570.l1313&_nkw=gsx1400+gauges&_sacat=0
I hope this link works
Thank You Gentlemen
Simonic
Thanks Froudy,
Yes,those are the ones I mean.
Thank You for your help.
I'll order some up
Cheers
Simon
Quote from: Simonic on Sunday, 28 October  2018, 09:22 PM
Thanks Froudy,
I'll order some up
Cheers
Simon
Just make sure you order the right ones for your model 14. The link that Froudy has provided is for the K5/6/7 models, if you want cases for the K2/3/4 then you need these
https://www.ebay.co.uk/itm/Speedometer-Tachometer-Gauges-Cover-Case-For-Suzuki-GSX-1400-2001-2003/131974279810?hash=item1eba47b282:g:BY0AAOSw8gVYBdwb:rk:10:pf:0
Good kit, I've fitted them for a couple of forum members, look as good as OEM
