Ignition Switch
Started by Simonic, Wednesday, 12 September 2018, 02:41 AM
Simonic
Can anyone recommend a pattern ignition switch that will actually work.
I've recently bought one and when i switch it on it only powers the tail light and the indicators.........
I shudder to think how much a genuine Suzuki one will be.......
Can't help but I would only buy from a UK place where it comes with a guarantee and you can send it back if it doesn't work.
Simonic
Quote from: seth on Wednesday, 12 September  2018, 03:10 AM
I did buy it inthe uk.
I've got to say tho.I got a full lock set inc a fuel cap and they are all nice quality. I'm wondering if the switch is for a bandit.
Do they have the same plugs ?
You can swop the lock part and the rest of the switch to give you a new lock but use your electrical parts .
Simonic
Thanks Seth. I'll give that a go
Bought a second hand ignition switch from a '01 sv650....  After i Too bought a complete China lockset for €25. The cheap set did not work, acted like on yours... It did not work.
With the ignition on...only the parking lights worked, on park.. Some of the electrics worked. I could not get it to work as intended by Suzuki.
If it's a K2/3/4, the ignition switch is the same as that fitted to GSX-R 600's - so you may find a good second hand one on eBay.
I assume you've also seen this thread http://gsx1400owners.org/forum/index.php?topic=321.0
Simonic
Yep.. had that one too.. or very similar.
