Occasional click, click , click
Started by Speedy1959, Monday, 11 June 2018, 03:30 PM
let us know your thoughts on new chain Col. i was amazed by mine. still am. stick my toe under every now n then, a good old aussie measurement, has not changed in 15ks. clean n lube the secret. gear oil rules.
@grog
Was considering doing what you have done but finally decided to throw sprockets at it too.
Chain was $180 with sprockets total was $309 nzd. Didnt think that was too bad.
That's correct about the pins Col, I have a few spare links off the 'old' RK chain I had.  The DID link pins are thicker & won't go into the hole on the RK chain, so you can tell straight away which is the stronger / more heavy duty chain IMO.
