Swing arm and rear end spruce up.
Started by Kiwifruit, Thursday, 14 June 2018, 08:41 AM
First up a thank you to those that put up the workshop manual link. Made life so much easier. Thought I had lost a cup spacer but exploded view shows only one.
Fitted a new chain and sprockets, while apart I decided to pull the swing arm and re-grease the bearings. Mine looked in good nick except for the grease being a bit thin.
Had been hearing a little creak for a while so also decided to grease the shock pivots and the brake torque arm pivots. Creak gone now and all very smooth. All those pivots were bone dry. My bad !! Did the brake lever and gear shift pivots too.
Only little things but you sure can notice the difference.
