Brake splitter
Started by lloydjames, Saturday, 05 May 2018, 06:36 PM
lloydjames
A quick easy one for someone to answer, When I bought my 14 it had the 2 line brake hose setup which I am going to revert back to 3 line when I get home next month. Does the splitter fasten to the bottom yoke or the headlight lower bracket?
Just asking because after swapping from the rusted twin light setup the previous owner fitted, I have fitted an aftermarket headlight and don't have the bracket.
Any pics would be appreciated.
It should fit to the lower side if the lower yoke .
There is a hole for the bolt and a recess and the opposite on the splitter.with the brake line connector facing forward .
:onya:
lloydjames
Just grabbed a couple of shots for you @lloydjames
