Head Stock Dimensions
Started by froudy, Saturday, 25 September 2021, 05:55 PM
A quick favour please.
A guy on the Suzuki Bandit forum intends putting a GSX1400 complete front end on a Mk1 1200 Bandit and has asked for advice. I've checked bearing dimensions top and bottom and they are the same for both bikes. What I need to know please if someone could kindly take a measurement is dimension "A" in the photo in mm.
Many thank you's :onya:
200mm on my K3 Froudy.
Can't seem to upload an image atm.
AmyTama
I'd also have a look at the simple maintenance items before chasing bigger problems. Fresh plugs, a clean air filter, and checking for any loose vacuum hoses or connectors can make a surprising difference. Sometimes it's the little things that end up being the fix.
Quote from: AmyTama on Tuesday, 07 July  2026, 11:49 PMI'd also have a look at the simple maintenance items before chasing bigger problems. Fresh plugs, a clean air filter, and checking for any loose vacuum hoses or connectors can make a surprising difference. Sometimes it's the little things that end up being the fix.
... and the award for the most random post of 2026 go's to ......  :happy1:
Phishing bot, be careful.  We get lots on the BMW USA K-Bike forum.
