Tubeless valve
Started by T 24, Saturday, 07 September 2019, 10:10 PM
Does anybody know the type or diameter of the tubeless valve?
Or the diameter of the hole in wheel?
It's a bit difficult to take the tubeless valve away and then go and buy new one with that same bike.
Bob
I think it's just bigger than 11mm, I have a bare wheel at work, if no one knows exact measurement I will get it for you Monday
Quote from: Bob on Saturday, 07 September  2019, 11:47 PM
Thanks in advance.
The correct tubeless valve type is TR 412.  Also TR 413 can be used, it's only a bit longer.
I prefer the right angle metal ones, soooooo much easier to check & adjust pressures.   There's no way I'd replace the originals with a like version, just me though.
Good info (for those that use them) on the oem valve part number T24.  :onya:
