Spring spacers
Started by mlivkovich, Thursday, 07 December 2017, 05:33 AM
mlivkovich
Had slight leakage on right leg seal so I ordered new seals and oil. Manual says that there are plastic spacers above springs. While rebuilding found metal tube and 2 washers in each leg instead of plastic spacer. Is it standard or previous owner changed something? K2 model..
have a good look through the old threads as I'm sure something very similar came up a few months ago.
as there are big differences between upto k4 and k5 on forks.
good luck
mlivkovich
Quote from: seth on Thursday, 07 December  2017, 06:10 AM
good luck
Thank you seth! Just found picture of k2 fork internals...mine are original too  :smile2:
V_i_c_i
K2-K4 have steel spacers and K5+ have plastic spacers
mlivkovich
