Cruise control
Started by Mrg, Friday, 02 October 2020, 11:07 PM
Mrg
Hi guys long time no see from me ,but I'd like to ask has anyone come across any good control units that they would recommend for cruise  control I do a lot of one hr riding to get to work and most is on a duel carriage way I've had the plastic holder and it's ok but just asking if anyone has had any good devices that they recommend cheers and hello all  :onya:
I have had a Brakeaway Cruise Control fitted for nearly as long as I've had the bike and use it most every ride.  Get the right size for the bars you're using (important) & follow the fit up instructions.  Works very well for me & also disengages should an emergency situation presents & you have to quickly squeeze the front brake.
https://brakeawayproducts.com/product/7cp02/
Mrg
Hi kiwicol just checked that out and in the drop menu it doesn't cover Gsx 1400 so witch one did you get your from on there site ie model please mate.  I like the look of this one and how it works cheer
The one in the link, 7cp02.  GSX1400 isn't listed as it's not sold in USA,  you need a 22mm bar version that fit say, a V-Strom or a Busa (which 7CP02 does) & it'll fit right on a 14 as well.
Mrg
Kiwicol cheers my friend yes I was looking at the list and the only one cam to mind was the bursa but I won't to check with you as you had it already thank you for the info cheer mate have a good day
Mrg
Hi kiwi I've ordered mine from the USA  8 was to get here no rush but I can't wait to try and use this bit of kit  cheers for your help and I think it's well worth the money  :onya:
I use mine every ride, just a normal thing for me now.
