throttle bodies
Started by mitch, Monday, 03 July 2017, 03:51 AM
mitch
anyboy know if all gsx1400 throttle bodies are same i have a k2 and suspect the drive has gone so going to buy some and try them
K1 bodies different, (not sure in what way),
K2 to K7 listed as exact same part number with Robinsons Foundry as are all the ancillary components.
copied this from another thread
hope it helps . :cheers:
Quote from: mitch on Monday, 03 July  2017, 03:51 AM
I think the difference is in the fuel rail but I'm sure all models are interchangeable. What do you mean by "drive has gone"?
drive has gone, i also dont understand.
Maybe @mitch  means the Secondary throttle valve actuator (STVA).
bigian14
Fairly sure they're the same other than the the fuel rail being made of steel on the early ones and aluminium on the later ones, or vice versa
mitch
thanks everybody thats what I wanted to know, by the drive I mean what drives the butterfly valves for choke, mine don't move and แบƒont start unless i bump it
There is no choke. If you mean the second butterflies those are the secondaries that limit airflow at lower revs to speed up the gas speed & make it run smoother.
Choke, secondaries, same thing really.
What you'll find if the secondaries don't move is a magnet has dislodged in the STVA. Easy fix but you need to separate the throttle bodies.
