Luggage: Help installing GSX1400 specific Givi pannier racks
Started by j_rider, Wednesday, 19 October 2022, 10:40 PM
Quote from: j_rider on Thursday, 20 October  2022, 09:40 PM
Quote from: BlueDragon on Thursday, 20 October  2022, 04:13 PM
That doesn't look like my new kit, the fitting brackets are different to mine.  But the pannier frame is the same.
But it also looks like you have the quick release adapter kit on your pannier frame.  You need the tri-pointed key to make it work from memory.
Thanks for the extra info @BlueDragon. Will try to chase down one of those tri-pointed tools.
@j_rider this is the tri-pointed givi key you are after https://mad4bikes.co.uk/givi-z2711r-key-for-quick-release-pannier-rails-plxr-plr-klr-klxr-cam/
You'll need to do a search on the Aussie sites though for a supplier down under - search on "Givi Z2711R"
Ron Angel in Adelaide is the GIVI wholesaler in Australia, I spoke to them on availability of parts but had to order through a local agent. You could try Carlisle Tyres and Accessories used to be in Ingleburn Western Sydney from memory.
j_rider
Thanks @gsxbarmy and @Irish in Oz for the extra info and leads.
I contacted Ron Angel, who pointed me to a local dealer. Got the tool coming in early next week.
Lenahan
Looking for help on here to refit luggage and eventually found that I had these downloaded on my laptop for years. Installation instructions and parts list for 527FZ and PL527.K527 MONOKEY top box and pannier racks. Only difference for single exhaust models is left rack bolts perpendicular using left a shanked bolt instead of footrest pin and circlip
Are they still available to purchase? I would like a set of pannier racks to go with my topbox if I decide to do a bit of a trip.
Batkwaka
Quote from: VladTepes on Sunday, 28 June  2026, 06:22 PMAre they still available to purchase? I would like a set of pannier racks to go with my topbox if I decide to do a bit of a trip.
I still have a set but they're over here in faraway WA.
Quote from: Batkwaka on Tuesday, 07 July  2026, 05:54 PM
closer than from the uk
Have a search around on here, or via google for just this site. People have adapted pannier racks off different bikes without too much hassle, as I recall it just means the panniers sit at a different angle.
Stepdoug
Correct think its  from the pre v- tec vfr800 and poss pre 2001. Same part number as a gsx but in different  order
