Throttle body dilemma
Started by SteveJ8672, Monday, 28 April 2025, 05:27 AM
SteveJ8672
Quote from: Hooli on Thursday, 01 May  2025, 05:53 PMOne thing you can check, the 'Y-shaped' adjuster with the fast idle screw in can stick on it's pivot. I had that years ago. Not only causes random idle speeds but will cause C28 (STVA) errors & the FI light on.
Because there's no feedback from the STVA the only way the ECU knows it's working is to monitor both the TPS & SPS to see the expected adjustments when it signals the STVA. So things out of adjustment there can cause it to think there's a STVA fault.
Nice one mate, will do.  :onya:
Used to be known as Nomad of the SOC many years ago, I'm just old. 2003 B&W being lovingly & painfully restored in the mancave. @VBG-thementalhealthrider
SteveJ8672
Latest update is hooray!, the couple of days soaking in the Plusgas then 2 to 3 days soaking in ACF50 did the trick and is nice and smooth with no resistance. Cheers to everyone with tips and offers.  :grin:  :clapping:  :onya:
Well done fella, patience is a virtue, i dont know about virtue but i do know it sometimes is needed😂
As usual the brains trust that is the devoted members here comes through with a solution and information galore on even the minutiae of problems  :cheers:  :cheers:  :cheers:
