PAIRS
Started by grog, Wednesday, 21 May 2025, 05:11 PM
I should know but i dont. Can i take off original pairs covers, remove reeds, block off air inlet holes and just refit.Then just remove hoses, block off air filter holes Is it necessary to fit blanking plates where reeds were? Mine has just had vacuum blocked forever, thought about time to remove properly. Thanks.
Yes, I believe you can.
That should work aye. I can't recall if there's a seal on the covers so a smear of sealant when they go back on might be a good idea.
What I did many years ago was cut two squares out of an old bit of scrap (LR wheelchock actually) the same size as the reed valves & fit that using the original rubber seal around it. No idea if it makes any difference but I figured a smooth top on the port might improve gasflow slightly over having a a bit of a chamber there to cause eddies & such.
I removed the pairs valves and refit the cover and seal with a light smear of instant gasket.
And that's it I have a spare set of the covers if you need very cheap at £15 the set .
I can't get pictures via my phone but its all very straightforward
I was in there recently.  I've had the vac lines blocked off forever too. Thought I would check. The original reeds are still in there. There's a nice rubber seal that actually retains the reeds. Mine were gunked up, so I took them out of the recess and cleaned them up, even removing the little screws that holds the spring plate on.
I figure as I don't have the blanking plates, having the reeds to block 99% of the hole, plus then the vacuum hose blocked off ensures a good seal.
One day I'll get the black anodised blanking plates, and matching black stainless bolts. I think they should mill them so that they slot into the recess where the reeds go, would make a better seal.
Quote from: Eric GSX1400K3 on Wednesday, 21 May  2025, 11:00 PMI was in there recently.  I've had the vac lines blocked off forever too. Thought I would check. The original reeds are still in there. There's a nice rubber seal that actually retains the reeds. Mine were gunked up, so I took them out of the recess and cleaned them up, even removing the little screws that holds the spring plate on.
The reeds need removed as they vibrate and have been know to snap off falling into the valves then replace everything else and all will be good .
This bit what I've done on all 3 bikes more than 50k Miles ago without any problems or leaks .
Quote from: grog on Wednesday, 21 May  2025, 05:11 PMI should know but i dont. Can i take off original pairs covers, remove reeds, block off air inlet holes and just refit.Then just remove hoses, block off air filter holes Is it necessary to fit blanking plates where reeds were? Mine has just had vacuum blocked forever, thought about time to remove properly. Thanks.
Yes you can. It will work. I did so years ago.
Phill P
I removed the reeds but left the actual mounting plate, did use the blanking plate with some sealer. Tidy up the top end really well, oh and it runs better at low revs.
Interesting, now I have another job to do. I just blanked my hoses off so now I'd better remove the reeds.
Cheers, will remove the reeds then.
Yes you can..
I did exactly that to my K7
I then put the original covers on backwards way round..
I cant remember how to post a photo on here !
Thanks Col
Here is what I did..
Very neat and near enough "factory"
I did get a friend to tap the original hose outlet for me..
Then bought "Black Stainless Dome headed Bolts"
