Brembo RCS clutch master size?
Started by lurch, Thursday, 21 November 2024, 05:21 PM
lurch
Anybody happen to know the recommended clutch master cylinder size when converting to Brembo RCS? I've tried a few different suppliers and none have the answers.
I scored a brand new 19RCS brake master from a mate as payment for some work. Now that it's been on the bike for a few weeks the clutch master being different is really bothering me. I'm aware of the lack of clutch switch but have a solution for that.
I had a search, seems same number for clutch cylinder. Not sure why bother, stock works fine, looks i guess,no advantage.
lurch
Quote from: grog on Thursday, 21 November  2024, 06:14 PMI had a search, seems same number for clutch cylinder. Not sure why bother, stock works fine, looks i guess,no advantage.
I've searched the forum and all the FB groups. Lots of mentions of swapping but none of the actual size.
Definitely not necessary but I've got a shed full of bikes that have suffered similarly 🙄
SpongeBob
For about the same (aesthetics, read: symmetry) reason, a 19RCS is fitted on mine for years and do work absolutely fine.
When I had, previously, a Nissin radial MC, it was 19 in size as well.
As for size comparison, I've installed a 17RCS on my MVAgusta Brutale 1090RR, which has a roughly equivalent clutch size (although it's a slipper clutch), but the slave cylinder is a bit smaller in diameter.
Here is a photo of my setup where you can also see 'special' reservoirs dedicated to Brembo MCs and that blend more nicely than the regular plastic hanging ones, especially on a naked bike.
And that look closer to original, which is quite important to me ;)
lurch
Quote from: SpongeBob on Thursday, 21 November  2024, 08:03 PMFor about the same (aesthetics, read: symmetry) reason, a 19RCS is fitted on mine for years and do work absolutely fine.
Thanks. I'm sticking with the plastic reservoirs for now but will probably upgrade in future. Those similar to yours sure are expensive and I think I've spent enough on this bike for now.
Side note - I miss my Brutale 1090R! That and a 2008 Speed Triple are two bikes I wish I hadn't sold.
