Front indicator connectors
Started by lurch, Friday, 15 November 2024, 09:16 PM
lurch
Are the indicator connectors inside the headlight supposed to be this style?
A previous owner had done some lovely "twist the wires together and tape it up" type connections for the rear and I tracked down original style connectors to tidy it up. The front currently has bullet style connectors that almost look like they should be there, but I may replace them with the OEM style too.
All 4 are the oem style AFAIK.
Yup, that's how they should look.
I can't remember if it's grey or black for left or right though.
Yes they are correct
You can get a universal bullet to the standard connector online amazon,eBay  and the likes so you'd just need to add a bullet connector to what you have then everything would work as it should  :cheers:
Daaef
Quote from: lurch on Friday, 15 November  2024, 09:16 PM..I tracked down original style connectors to tidy it up.
Hey Lurch, don't suppose you have the part number and Aus source handy?
lurch
Quote from: Daaef on Saturday, 23 November  2024, 09:26 AM
I didn't manage to find them in Australia unfortunately. Sourced them (non-genuine) from Webike Japan along with a few other parts I was chasing
Daytona 96193 (black)
Daytone 96194 (grey)
lurch
Also just in case anyone finds this topic in future when searching - here's a photo I found showing which wire colours go to the black and grey connectors. I haven't had a look to work out which is left or right, but you'll work it out.
Daaef
Thanks Lurch,
Yep grey is left of bike in Aus too
