GSX1400 Clutch Slave Cylinder any other options
Started by DGK5, Saturday, 16 April 2022, 09:29 PM
DGK5
Just asking if the K5   GSX1400 Clutch Slave Cylinder is a stand-alone part ???. if not, what other Suzuki Bikes use the same Clutch Slave Cylinder. Just that I would like to get a 2nd one to have in my spare parts box,  thanks for your help cheers Phil
mlivkovich
It looks like it is same part number for gsxr1100 (w and oilcooled), bandit 1200, rf900 and hayabusa gen1 :cheers:
DGK5
DGK, get the extra Busa seal and fit. All instructions on here. Using gear oil as chain lube stops a lot of crap around slave. VMX Castrol is good. Other slave trick is get pushrod out, smooth it down, make up grease/oil mix, in manual, re lube it. Gotta be precious with that rod, if seal stuffs up its a motor split. Not preaching but things necessary.
