Lcd and starting not working
Started by Mrjohno666, Monday, 08 February 2021, 03:12 AM
Mrjohno666
So fitted a new front light unplugged everything fitted new light and turn signals put all plugs back in as was was tight putting front back on but now when turn on both clicks turn over but bike is dead  doesn't even sound like its priming the injectors
Johno😆
It has to be something you've just done, retrace your steps & you'll find it. Wrong plug in somewhere? loose connection? Missed a plug? Something has come apart / out when stuffing it all back into the light?
If you are getting clicking and nothing else, then either the battery is flat or something is earthing out taking all the charge (a typical place for this is by the headstocks and/or where the wires come into the headlamp shell).
I'd start by removing the headlight and seeing if she'll start. Oh and put the battery on charge
SFC1000
If all else fails pull the plugs apart and have a look in all to make sure a pin hasn't been bent or crushed making it come out of contact.
CAUTION - My forum posts may be worth what you paid for them!
You have alarm sticker, is it also immobiliser? If so, maybe thats kicked in. Otherwise, as already said, something not re connected properly. Re trace steps.
It can't be plugged in right as the key is on yet there's nothing displayed in the LCD portions of the clocks.
Check 10A fuse No.3. It's the supply for the clocks. If this has blown or the wire is broken/not connected you'll get this fault :onya:
