Suggestions please - my bike will not start.
Started by Alan Moreton, Friday, 20 December 2019, 12:37 AM
Quote from: seth on Friday, 27 December  2019, 07:22 PM
@Hooli the plug leads are sealed (for as long as it lasts)into the coils at that end.
I think all this chat is about trimming the plugcap end of the leads.
It helped with emma's bikes wet running trimming the plugcap ends of her HT leads.
Aye I was referring to the plug end too Seth.
Mine tends to run on about 2 1/2 pots for the first half mile on cold damp mornings (under about 5c) then behave. Smacks of damp ignition to me, not really surprising as I've never touched the leads excreta except to occasionally take the plugs out.
Another good way to check your leads and plug caps for leakage is to wet your hands and run them over the HT area's while engine is running, if there's a problem you will soon pinpoint it.
Just had another thought about this, probably better to replace the caps as that's likely where the corrosion is, I am assuming the leads are carbon, I'd be surprised if they are not.
Quote from: Irish in Oz on Saturday, 28 December  2019, 06:15 AM
Would it not be more accurate if you used your tongue ?
Quote from: Kiwifruit on Saturday, 28 December  2019, 03:21 PM
As a lot of us are getting old, you could use your dick to save bending down
Quote from: Hooli on Saturday, 28 December  2019, 05:37 PM
Doesn't work for all of us now... Would It?
I would still need to bend my knees... And With an unheated shed....My reach is limited to belly button size  :rolleyes:
To go off topic from the current topic...
I trimmed my leads when I got home on the bike tonight so I'll see if it works in the morning as I'm off out again.
