SV1000 front wheel onto 1400
Started by GSX1400Convert, Monday, 27 May 2019, 07:49 AM
GSX1400Convert
Does anyone know if the 2003 SV1000 front wheel will fit the 2008 1400 forks/disc rotors?
I know the SV uses 310mm rotors, but I don't know if the wheels themselves interchange.
The initial attraction to motorcycling inflicts people for various reasons and at different stages in their lives. But once someone experiences the elation of riding a motorcycle there's no denying the nearly spiritual effect it has.
Go to Robinsons Suzuki and cross reference the part numbers .
If using radial calipers if the wheel and discs are the same then you might just get away with it all as I've just found i need spacers on the calipers  to fit a gsx1400 wheel the a bking front as gsx has 320mm discs and the bking has 310mm ones .
Good luck
GSX1400Convert
Thanks, what a great resource, but, numbers vary
GSX1400 is: 5411-33E10.019
SV1000 is: 5411-35F11.019
Could the middle section be the colour?
If not, has anyone a bare 1400 front wheel that they could measure OD of the centering flange for the rotor, and the distance across rotor faces of the rim (where the inside of the rotors bolts on)
Thanks in advance.
