Down pipes and headers
Started by Gixerkid, Friday, 11 May 2018, 08:28 AM
Gixerkid
Exhaust is blowing on my K3 between the headers and collector,decided on some new downpipes and collector box and keeping my original end cans..
Seen the Delkeviks on ebay for £250...would i need to do anything to the fueling if I was to fit these...cheers
Would you NEED to?  No, you wouldn't.
But ideally you would get a dynotune done (do you have a power commander?) to get the best out of the new system.
I agree you should not have to, should be a straight swap, but if you do have a power commander fitted with a custom  map it might need tweaking
Gixerkid
Gixerkid
As I was ready to buy the Delkevik down pipes and collector I had a change of heart and decided to get the full system.....should I go Delkevik or Black widow?
If your going for a full system akroprovic is the way to go
RickC
If you are keeping 4-2 I would go Delkevic, the stainless stays looking a little bit better than the Black Widow.
The Delkevic collector looks a bit better with the stainless trim not unlike the original collector.
Both are single skinned so the performance of both are about the same.
If your going for a full 4-1 or 4-2 you'll need a power commander and a remap .
