Rearset Mounting Bolts
Started by CraigL, Saturday, 03 March 2018, 05:58 AM
CraigL
Does anyone know where you can get stainless steel bolts to replace the original rearset to frame mounting bolts.
I've tried ProBolt but the ones they supply only have a head diameter of approx 16mm whereas the originals are nearer 25mm.
Craig
And the Answer is.......Probolt.
You won't find exact match originals, but I replaced mine using Probolt, what you need are countersunk aluminium washers and countersunk bolts (Stainless, not aluminium). The countersunk washer is exactly the right size to fit in the hanger holes. In my K7 (when I had it), I had blue countersunk washers with stainless countersunk bolts
CraigL
Many thanks Barmy.
I'd never thought of the countersink/solid cup washer idea, I've seen the penny washer and button head Allen bolt idea but didn't really like the look.
Back to ProBolt 👍
Once again, thank you.
