Lights flashing
Started by Gixerkid, Thursday, 08 August 2019, 02:32 AM
Gixerkid
Having followed the wiring diagram in the haynes manual I have narrowed it down to the circuit that is labelled E which does the indicators,horn,brake lights etc and all these create the original problem ...having checked continuity on everything and all is good except that there is no continuity between the orange and green wire that supplies the feed to all the above from the fusebox and the last connection on the relay that does the indicators.....my only concern is that its labeled as a negative on the relay but cant be as its just a loop thats joined back onto the outgoing positive from the fuse box( if this makes sense)
Gixerkid
My plan tomorrow is to trace this wire from the relay through the loom until I can see where the break is ......this must be the problem Id have thought any feedback would be great
Will14
Quote from: Gixerkid on Thursday, 15 August  2019, 07:34 AM
If you haven't done so already it may be worth checking the loom behind the headlight where it is clipped to the top of the chassis under the tank, I can recall a mates 1400 having a repair done there by the dealer when it was only a couple of years old, it was a 2002 model
Cheers
Pete
Gixerkid
Been at it for a couple of hours again snd still no joy....
If Ive checked continuity to every wire thats in this circuit and they are all ok and also checked that Im not getting continuity anywhere between the positive and negative wires(no shorting out) I cant see what else it could be...pissed off is an understatement
Gixerkid
Quote from: KiwiCol on Friday, 16 August  2019, 08:13 AM
maybe auto-sparky time.
Could well be as I threatened to sell the 14 tonight
